i take it this happened when you lot were on the piss out somewhere?
All of them bar me and another mate, yeh.
A mate got teh Gin bottle out, and thought they would mix "Gin and Juice" coz Snoop Dogg does? lol. There Gin to juice ratio was a bit out, and finished them off.
come on people, they'll be here soon!
so far suggestions are:
1) answer the door naked, and ask them, " Are you here for the gangbang"
2) call building management
3) Shoot them
4) Call security?
5) ring cops - tresspassers
6) beat them
7) bucket of water and if avalible add coloured cordial and open the door and throw it over them!
8) draw a pentogram and stick it to the front door and hope they're jehova's witnesses
Tell them your Jewish?
bahaha yea tim and the gin and juice......
Tim tried to tell Jamie an I the other week that he needs an ex/waste gate to stop boost flare :thumbsup: We let it slide.... Untill Sat night. If it wasn't so dark I would have got on him cam trying to explain what this said boost flare problem is...
To be honest I still don't know haha.
We think in short, he just wants the gate so it can go DOODOO CHHAA DOOODOO, hahaha.
and all this from an ex mechanic...its scary
his car is reasonably stock isnt it?? I didnt really talk to him bout it the other night..
Stock.. and he wants a top mount and put stock turbo back on, with ex waste gate, so its more easy to upgrade later?
Wont listen to me, or anyone. Oh well.
does he bat for the other team? :thumbsup:
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
