if u have problems with companies these days and need telephone support and know there call centre is in india or somewhere of that nature. go to there store and talk to someone who is able to speak english and if telephone support is then needed, make them make the call and talk to the operator :D
or just give up altogether and change companies!!!!! :)
Mangrove Jack?
they must've come down in price if so.... last time i looked they were around $120 for a fingerling
$120!!!
who wants one........
I'll go and throw the cast net in this arvo and see what I come up with.....
little barra
baby mangrove jack......
all sorts of cool little fishies....... :)
maybe if u take it to a tuner that knows what they are doing?
lol but seriously, whats wrong with it now?
Arent you using mercury :)
My last tune was done by one of the best in Sydney, it is good and the frist lot did an amazing job since they tuned it with an air leak the size of a 50c piece!
Not sure what is wrong, but it surges under load, maybe the clutch needs rebuilding (I bought it with not alot left on it), Maybe the turbo is broken or too small, Maybe the leaky gasket is causing it, maybe there is a restriction somwhere else in the exhasut. It is going to ba annoying that is for sure
yep i certainly am using mercury, and they are looking after me quite well :mad:
I can't see how the clutch could make the car surge under load, if it was stuffed, it'd be slipping. Like i said, take it somewhere and get them to have a good look at it. Tell them what's going on with it, and get them to check it out. and change that bloody leaky gasket, u lazy ass :D
yep i certainly am using mercury, and they are looking after me quite well :)
I can't see how the clutch could make the car surge under load, if it was stuffed, it'd be slipping. Like i said, take it somewhere and get them to have a good look at it. Tell them what's going on with it, and get them to check it out. and change that bloody leaky gasket, u lazy ass :)
If it is only beginning to slip it could have surging effect, eg it grips and slips periodically
I really hate those bolts at the back of the turbo...im not doing it again some workshop can do it I have taken that farking thin off about 5 times this year and I am over it lol
I want this for my "drive to gatton and carry stuff that the skyline can fit" car
How wierd is it
just brought some GANADOR STYLE review side mirrors for the car :)
goin to get some nismo clear side indicators this wknd
should bring part of the 'exterior' look up to what i'm wanting.
got a bit more to do though :)
ahh yehhh
that be flash eh brudda
    • Stock ECU (or more accurately stock tune) absolutely refuses to go over 10psi and behaves like you have seen. The Nistune is the same if it is the stock tune. If the Nistune chip has been tuned, the resulting tune could be literally anything for any combination of parts. The Nistune just makes the stock ECU Tunable.
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
