he he he now you know what would be fun??
a whole page of REALLY BIG POSTS!!
but my work sucks, come Chrissi everyone else is winding down, me no i get even more work!!
Oh well.....
:) i dont have my car back yet!!
ha ha ha i raced this s14 last night in my little bros 33.....
beat him in 1st 2nd 3rd and 4th, stoped there but he kept going......
got done by the cops down the road from us.....
i was so lucky not to get caught :laugh:
only got pulled over for an RBT and Licence Check.....
Burgandy side mirros, black looks poor. Unless its carbon fibre i guess.
which looks better?
burgandy colour side review mirrors
or
black colour side review mirrors
pics -
sideskirts are on there way!!!!
the front bar stays as is. its a 400R bar.
best lookin bar i reckon - got that tough look to it. hehe
wait till you see the final outcome of the car.
i've had a photochop pic done up for me and looks f**kin tough!!
cf FTW!!! although it would look kinda out of place without a cf bonnet :)
yessssssssssssss :laugh:
hey fellas get a load of this pic. I did a clutch in a mates car last nite, and this is what i found when i pulled the box out. That furry looking stuff was all inside the bellhousing, and its the actual organic clutch packs from the clutch face :laugh:
Looks like mine, we had to pry it off the flywheel as it had fused its self on.
2nd gear, limiter dump and 10psi hahaha
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
