well give me the dirty one then :P I will clean it and use it on something at my place :)
Hahahah, a microwave pod filter lol,
yeah, when i buy replacement, i will give it to ya, (as long as i remember)
umm I think its - 6 but don't quote me it should say on the garret website.
Also have you made them up before as they can be a bit tricky??
cool, will make it reasonably cheap then...nah never, mercury are making them up for me (discounts ftw hehe)
Hmm shane, week after christmas, bring a welder etc and i pay u to instal the cooler, with sexual dollars :laugh:
sexual favours from the female kind i'll accept, sorry bryn but this time u jsut wont cut it :thumbsup:
they aren't hard to do just have to have a couple of goes at it I thinki have a sheet from speedflow around here showing the proper way of doing it. A lot of people have a restrictor at the turbo and then run slightly larger lines, but like I said check their site and consult with a professional (I am definatly not one of them and am still learing the principles or an RB and its construction)
well my standard piping has a metal nipple thing that a vaccum hose attaches to, i asked around and i was told that only r32s had these, :thumbsup: but anyway, he basically said cut a hole and weld the standard one (or a new one) into place and bam your done,
and i dont have a clue what i doing, id rather pay someone and pick it up done
can u make me a copy of that sheet and bring it to dinner on tuesday? as i said, i get things on the cheap from mercury, and it saves me the stuffing around of finding suppliers for the fittings, and making them up.
i asked dan about the restrictor whilst he was out here friday nite, so thats all good :thumbsup:
    • The speedo's can be very conservative, when my Mazda NC MX5 speedo is showing 118kph, the GPS, and a calibrated radar.... cop mate.....hits me at around 110kph +/- 1 or 2 kph, and that is on a 215/45 17, stock tyres size is 205/45 17 as well, so weirdly conservative with stock tyre size When my Commodore speedo red 116kph GPS had me at 110kph After doing some offset and clearance measurements to see what can fit the NC on 17x8 +40, without guard rolling or rubbing anything at my current ride height, I've decided that when my tyres are toast, I'm going to fit 225/45 17 and see where that gets me IRT actual speed of my speedo and GPS/radar From the online calculator I should be still be doing around 5kph under an actual 110kph when the speedo is showing 110kph My ADHD requires that when I'm doing 110kph on the speedo, that the actual road speed is actually really close to that, and not alot slower And going from 205 to 225 still keeps the car within the %/mm allowable in the NSW vehicle rules and regulations, which is nice, as long as I'm looking at the latest version that is.....LOL https://www.nsw.gov.au/sites/default/files/2021-02/RMS-13.464-Light-vehicle-modifications-Vehicle-Standards-Information-No-6-November-2013.pdf
    • Take the value it measured as, and pick the closest range available that is above the reading on the screen.   Also, no point just testing the coils. Read what has been said again. You need to test all your wiring, everything.
    • Does the scanner do all the CUs in the car, or only the ECU?
    • @666DAN sorry to bring you and old thread.     I've got my de+t done and it's all running great other than 1 small issue.    Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd when selected . But nothing when in  drive or what gear your in when you pop it into tiptronic. I'm sure there is maybe 1 wire in the ecu plug I need to move to rectify this. Do ya have any ideas?     Cheers man
    • Well I recently changed my rear axles and was thinking if I bumped anything, I have been driving the car for a while now though... But it has been raining today so everything is wet under the wheel arches. Brakes feel fine and can't hear any of the metal screamers, I had a squeak coming from one of the handbrake drums but that seems to have gone away a while ago. I was going down a hill when it lit up and I did feel the abs bite for a second and question why it did it?
