who would of thought youtube be successfull in helping solve a crime.
wont be long till car forums will be phrased for there works in gettin all the hoons together and arrested for "being a hoon".
:D
Technically it wasn't youtube that helped "solve" the crime....
the dude just got a Major case of the "guilty" conscience....
the vidoe prolly will help him get off with a light punishment cos he has seen what footage was catpured and can make a story to fit as to get a lighter punishment, self defence any one??
i'm here, but just not awake yet. gimme a couple of days and i'll be good.
i'm not gonna get sick of your avatar for a while phatboi2010 :D nice
Waht? :D i wish i could see what your seeing
:w00t: maybe its just me hallucinating from lack of sleep. damn :D and :sorcerer: messin wit my head
:D iTS NOT YOU!! I SEE IT NOW yay!!!!
BUT I HOPE I DONT GET IT DELETED LIKE LAST TIME.....
morning kazza.
just read the dyno post again, fark its gonna be a massive event with great coverage! :D
but shane will your car be ready by then :D
:w00t: I get mine back tonight!!! Just in time for the holidays!!! :D
good to know i'm not going crazy..............that leprachon lied to me!
morning karen :D
morning karen :w00t:
Leprachons :D:D
:D Last time he told me to burn the school down and hell give me a pot of gold but he hasn't bought me one yet.... :(
Leprachons :D:D
:w00t: Last time he told me to burn the school down and hell give me a pot of gold but he hasn't bought me one yet.... :D
he told me to steal him some drugs and i'd get a new bike for christmas. still waiting on that
come on new bike
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
