also the suspension i was planning to buy in a few weeks through sydney kid, they stopped production of the front suspension for R33. so now that is ruined aswell, i just cant win can i. one thing i do need though is a new clutch, very soon id say, doesn any1 know what type to get?
i want one to handle about 300rwhp, but still want it to be streetable... bcoz i mite aswell get the clutch now while i am changing it so that when or if i modify for more hp eventually i wll already have the clucth there.
daz, get one from jim berry. i put one of his full monty's in a 33 gts-t last week and took it for a drive, farken lovely clutch it is! i've done 6 gtst clutches now, they're a piece of piss ;)
i need to afford to drive my car i dont wanna just look at it lol bcoz if u bought a gtr thats what id be doing. i couldnt afford to maintain it.
being up here on the coast what is the best way of getting a clutch from jim berry? i mean i dont really know how to fit them either lol and i coudl buy one 2moro if i had to, but then u gota get the fly wheel machined etc so its not as easy and in and out is it.
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
