dsajgasdofgjsdaflj
dsjlfkjasdgbfkjasgbdv
sdjlfgvbjkasdgvbjkbasdkvjb
sdjlgvbjksadgvbjkvbasd;b
ldjkasfvjklasdgbfuogsldjfvjlasdgvb
sdljkvjklasdgbvjkbsdjkvbkjsbdvjlb
sdjvbsadjkbvuiowerobusdiobavkjblkasjdbv
sdjklvbjasdbv;jbsadjvkbisuadbvjkasdbv
sadjklgvbjkasdgbvuiwgberiovbjkl;asdbv
sadjlvbkjsdgbvo[asuidfvihdsavnlask;vb
sdkl;vboiasufiweiofvnionrfhweigvbo
dnspifbhiowncvwioernfionwdifnviowe
ewiopfhiowehfwhneiofhnikfgov
,dvncc,.zxvnm,whaerioqeoi[tgds
gasdrt09273405toihfgba9u8htw
wio0v8734gfb5u4gnkonasdff789awh
asdf90828345tgu3gjivb807agh8 r7h
hrw9t78q49785tqiohasbdv78art34uijkwfe98goui
w89e4ghfoiasldkhfkasdhfaisdurtklawhef90ae749nkldfyhasdifhldkahlkdhlkdhfkla
l;kasdhfiowehfklashdfioehwoihflkasdhfuiowegroiw;'efjklskldhf
.,cbnvmzbm,.bcvbouibwjbfvvuoisdahgowei
hsdklbvmbweiobvouwbav,mboixcugvbwuiora
sadbovkbiwoervbobsdavmbm,bcvoiborwie
dsklbfmbweqiofubojklewgbfu8iower8ru
asdiofhoeiqwykwblembfbvc,.CBMZXUIOra;gbvoabv
saljkfm,wbefjuiwbjbgv,mbxajkfg982yrlkghrflkbasdfbas
adsoryoqweyrklhdflkhasdklfhjasdhfjkhdsjkfhjksadfhkjsdhfjkl
asdjklfgeioyrhdsahfuiwerjvbkw89rioriorioriorioriorioriorioriorioriorioeu]
kyugibjktjktjrtol
jhdjcpfsdagjioprwejhgnsfpahnvipohwg
slajlsjdkjklas;dfjiehfkhdga
Ekljsdfgioashtkrheaishivblkbn.anv
asldhfherw90fgihrweinv,nsda,.nvkldhfoiwer
asdhfgkansdnvklasdhioyhiohwrietklhasdg
asldhfkhaiosdhfouiwervbjkbmzxc,bvuioptasipdyhfkl;hasf
asl;dhfiopweyrto0weyirhklhdhfkldfkljdsfkl;ythhe thets the
the eht eht ejrtkretjiayfuvbjqwotuewtyjdkj;sdklfuioehlkfsdgh
asdklhfioeyrkldshfdljkashfdjfkj;kldjsfkl;sdjatkudkl;shfdksvbklk;d
sdkhhfklasdhiroheqwl;khfklsdbhamvdhsrlkhwioefhlksdbhvlbkas
sadkfhiowerhfiowq hfihkldhfklh khdfkhdsnvuwgu8egrtqwoeiyirdaksf
weoryhi9pyr9082yriehkcklneiovh8w9gh4irkelbfkbsdafuipq4rgb
eoghiorqeyr9023rknelmf nqweoiurhf2890h34rf khfkldnfklwbeioryh20[r
ewrhqweyhrioh;fkh;ldisrfyhqwegrtf3q4nionrklewnfio
As you can Plainly See, I AM FARKING BORED!!!!
man i think i'm gonna have to go srew one of the girls here at work far there is this Kiwi Girl with the nicest ass and a great rack... i wonder if sahe's ever done porn like the other Kiwi Temp?
bahahah have u upset linh again lee? :pirate:
nah she's in Vietnam with her mum.....
it aint cheating right if SHE's in another country right? :)
bawahahahhahahaha
and we were payin on out shane for havin ghey times with lee yesterday.
but i think shane would now perfer the 14yr old over u lee
you were talking about me :P
but y dont we just make it a :no:
nah id be worried about john being gay, caus all he could talk about yesterday was gays, and accusing people of being gay. it's okay john, u can come out of that closet if u want, and im sure lee would be gentle with u :)
thats right lee, how long do u have to go out for? and i think she'll be walkin a bit funny for a few days when she gets back :no:
nah id be worried about john being gay, caus all he could talk about yesterday was gays, and accusing people of being gay. it's okay john, u can come out of that closet if u want, and im sure lee would be gentle with u :pirate:
thats right lee, how long do u have to go out for? and i think she'll be walkin a bit funny for a few days when she gets back :P
Walking??? ha ha ha she wont have the energy!!! :)
Gentel with John :P Break out the Whips and Chains!!! Oh dont forget the Saddel!!!! :no:
MMmmmm.... Skinny Little White Boys FTW!!!
ha ha ha
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
