not abusin it :D
just showin that i can do it
:D i hate show offs....
lucky you have the goods to back up your claims :) or you might end up like other individuals *Hint hint* Eddie
yeah but thats like me kickin you in the nuts, proves that i can do it but prob shouldnt :)
once again.............
DDDOOOOO IIIIIITTTTTT!!!!!!!!!!!
lol
this is a family site
bad examples leads to big crimes u know :P
he's had his car nicked, sleeped with a work mate, becomw the SAU Whore what else could possible be done to him???
lucky you have the goods to back up your claims :D or you might end up like other individuals *Hint hint* Eddie
sacked for sexual harassement.
lol
:D and all in three weeks, damn i've been busy!
Edited by lilmike86
lol
i dont think she can even spell it, let alone file a case for it!
also, she not here, so cant get pics, got the fat pubmole today
Edited by lilmike86
now
i've found these new leather protector things
to replace those leather things around the gearstick and hand brake.
they look awesome... pure italian leather with 'nismo' embroided into it.
im gettin me some of these :)
i have white Leather gear boot and hand brake covers for my sil and my little bros Skyline cost us 12 bucks. looks great and if you want nismo embroided i can ask my mum to do it on her sewing machine or go to the cap factory......
your paying way to much for 2 bits of leather!!
$5 wtf?
wat r u, piss poor!
make a $10 donation ya pov bastard.
i'm poor :D whats it to you???? :D
can u do it like these ones -
then in that case
fall pregnant
bawahahahahA
being the s**t she is she had one of those rods inserted, also a few graphical discussions (at my expense)
her "you know i got my-"
mike "OMG I DONT WANT TO KNOW THAT! BBLAH BLAH BLAH" *covering ears*
so yeah
the embroidery will have to be done at the cap factory cost you like 10-15 and the grear boots are a easy, look on ebay, or do what i did my friend spent 55 bucks on his and then before he put it on i got a friend of mine who does sewing for a living and she made us 2 sets for 5 bucks each only a little bit of leather....
but man white gets so dirty....
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
