its taken me a few hours, but the house just hit 19 degrees, only 3 degrees to drop and im done
lol nice work. i'mdoing the same at my office, just it only takes 15 mins with industrial size aircon and ducting :)
i has fully ducting, and two MASSVIE (for home use) air con units out side, just takes it time :ninja:
this one is my favourite
http://freenet-homepage.de/dhpics/keeley_hazell/5.jpg
the bra could be smaller though
dude same photo but mines bigger :)
but i will tkae yours now cos then i can see it!!
wrong???
about the brunett thing??
no i was talking bout your posts not the other lee's
WOW thats a huge boob pic
i know :)
i know!!
where mike gone??
you think he's gettting busted for that pic before??
or is he off killing Kittens again....
no, not killing kittens. had a phone call, and got mars bar from servo. back now, no need to get stressed. i will still screw you all, just let me get ready first
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
