is it soo big its like throwin a bananna down the hallway? do u play the game 'try and touch the sides'
:happy:
nah, i just start from the sides and work my way in, less effort that way :happy:
hey she woulda been semi hot if she had any sort of rack, and didnt look like a 14yr old :happy:
ask ian for her friends number
and then get her number from her friend...
surely we can organise a better rack for her just for u shane.
but shes only 14... dont think shes even started to develop yet
coz john knows what age they develop at. he's been through the ages to check :happy:
I can't understand why people like this get jobs PROMOTING clothes....they look frightful
Go on stick figure EAT SOME MEAT!!! :happy:
last swimwear comp i went to with a mate....
we were sittin there eatin macca's... this skinny ugly thing came out
and damo offered her his burger "hey, want some meat?"
ppl around us that heard started laughing.
she came last in the comp though.
:happy:
well yeh, ur sister was a great help...
i've since progressed onto when menopause starts with ur mother now.
i dont have a sister, only a brother :happy: looks like john got it wrong, and in a bad way. is this a common problem for you john?
well ur brother looks and acts like a female.
tell him to stop dressin up in your mothers clothes then
dude, he plays football. he looks more manly than most of hte guys online here, and could prob beat most of them up too :happy: does that mean that you were the b*tch?
still.... were you "giving" or "reciving" John?
:happy:
what about Shanes feelings???
but you told me your brother could be what ever i wanted him to be :happy:
in that case i'm not comeing over for the futurama Marathon/orgy ;)
in that case i'm not comeing over for the futurama Marathon/orgy :happy:
he would for you lee, coz your special ;)
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
    • ECUtalk pages don't mention they support the ABS computer (consult port has more than one CAN), so you might just need a different scan tool. But, I would expect ABS is a different light to the brake warning/handbrake light, do you see an ABS light come on for a few seconds when you turn the key from ACC to IGN? But since you said: I'd have a look at the ABS sensors in the rear hubs to make sure they are not damaged, disconnected etc.
