okay peoples!! mike is going home for the day! no more work!! YAY!!! sadly that means you wont see me till tomorrow >_< but thats ok you will just have to remember the fun times and look back on all the used condoms >_<
i'm outta here, cya's :)
teabagged...
lawl I posted that on someone's myspace a while back. They did teabag me first though :laugh:
Okay whatever party they at, i'm there! :):laugh:
Fark my sister'd love that LOL
Sorry guys... i got so bored i went home.......
pics tomorrow!!!
otay one for now
ZOMG you can totally be my friend! I have teh yellow FEVER! :rant::laugh:
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
