slide...
how much for a complete kit for the GT3540R (including high mount manifold, wastegate, etc)??
unless you want a hks manifold i dont really sell the cheaper ones unless i have to
theres nothing really wrong with them but the output to the flange requires die grinder work
tial 38mm gate with 1.2 bar spring $405 Delivered
tial 44mm gate with 1.2 bar spring $605 Delivered
GT3540R-IW, $1695 Delivered
wat?
ur makin no sense dude
but thats whoretown for ya
otay..
she's back from Vietnam and has used up all the money on the credit card (my credit card)
thats what i was tring to say.....
shhess....... stop with the drugs at work John.......
send them to me >_<
:happy: its just she spent all the money in Vietnam...
but i can still give out bum sex....
just Anna and Virgin dont belong in the same sentence
Bubbles hey? where can i get this stuff? >_<
you cant lol
if someone wants to make me a qld sponsor ill do better prices
im already a nsw sponsor >_<
muhahahahahahah :P
I want to join the Dark side son of rajab Vader !!! >_<
twins are for girls
Shuddup you ...
Just cause you stole your engine out of an R33 ...
Bloody forged pistons and big single wielding punks :happy:
why do i get the feeling that this mornings boostloosin thread has attracted some of the users over to this thread?
we seem more populated today then most other days.
i seem to attract people wherever i go
its a bad thing
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
