Yeh that would be cool :D
Send a PM to Marc and let him know what you are prepared to offer club members in the way of discounts and/or benefits
He will reply to you shortly thereafter :) He had better anyway or he gets :no:
hahaha ok ill send him a pm shortly
whoa, now there's two anna's. this could get confusing :no:
There is no confusion. I am THE Anna. The only one you need to know :D
yeah
but doesnt give the business any right to "not give a shit about it"
as you can see now, that will badly reflect back on them.
they aren't willing to do anything about it or come to a comprimisation about any of it.
i asked "well how about i ask how much would it cost to have it properly fitted and we can look at going halves in the cost of this".
he simply said "nahh, im not willing to cause its out of my hands".
what a f**kin lame ass business would say somethin like that to a customer.
That is pretty shit :)
and side kick
roundhouse kick?
dont give him any ideas
he`ll wanna go out back for afternoon tea with you soon :no:
hoorah!
ha ha ha I noticed it but heaps of people call me Anne anyways :)
ew I hate that name
I've noted your edit, but its toooooo late :)
Your mistake remains in whoretown for everyone to see FOREVA :D
hmmmm, really. we'll see about that *runs outside and starts the car*
*runs back inside* forgot my wallet :)
ha ha ha I noticed it but heaps of people call me Anne anyways :kiss:
Hello to you too!
:P
ha! see karen, doesnt matter! :no:
and just to rub it in more :D
yeah
i cant wait to see their reaction
its sort of metaphorically speaking stabed them
    • Ha, well, it's been.... a bit of a journey. Things have taken much longer than I'd hoped. I'll probably put up a thread at some stage. Hopefully soon. The car's not done any kms since my update in June though, put it that way.
    • Here's the chart for fuel pressure vs. current draw, assuming your base fuel pressure is 3 bar and you run like 0.5bar boost on WOT, you should only momentarily hit 9amps here and there. (Ignore my prev post, I cannot read a chart these days it seems)
    • Those comp test results are not hideous. Whether they are accurate or not (ie, when that comp tester says 140 psi, is the real pressure120, 140 or 160?) is unknown to us. The state of the battery used to crank it over is unknown, etc etc. Many people around here would say that the absolute values and the spread are perfectly fine to just add boost and keep going. I personally would be happier with a narrower spread than that, but even the diff between 125 and 145 is not terrible. That one cylinder at 125 though, has probably copped some damage relative to the others. You should inspect the valves seeing as you've got it open. Do you know how to measure installed ring gaps? That, and an inspection of the rings themselves, is how you will determine whether they need to be replaced. If you're not good to do these things, take the block and the pistons and rings to a shop that is, and ask them for the go/no-go on them. Do the bores need a hone at all? If so, you might well be justified in getting some different pistons in order to get away from the ring supply problem. Whether you're happy to spend a lot more money right now, on more gear, rather than less money, but an amount that looks stupid given that you will only get a handful of rings in exchange for that money, is for you to decide.
    • also possibly backed up to my filler and shat down it! 🤣
    • Ok so i would love some advice here please, i purchased an R33 a few months back and its had a few mods done to the engine, its an RB25det running a Master ECU, 1200cc injectors, bigger turbo, oil cooler, oil filter relocation kit, Spool H-beam rods, acl/ross pistons. When i removed the motor from the vehicle (as its getting a respray) i thought i would compression test it and these are the following results. Cylinder 1-145psi, Cylinder 2-143psi, Cylinder 3-125psi, Cylinder 4-145psi, Cylinder 5-140psi, Cylinder 6-135psi this test was done with the motor on the ground and powering up the starter motor. I dropped the sump and found broken oil squirters on cylinder 3,5 and 6. I was told my rings are probably worn so i stripped the motor completely to get a new set of rings for it. The trouble is no one has these rings anywhere and they have to be custom made by Ross over in the states and will cost about $600+$200 delivery. My question is how can i tell if my rings are at fault and if they are still ok and is this price ok for a set of rings?
