its all practical shanef so how does it justify the ricer tag????
And no i didn't get an N1 water pump as the rb30 water pump flows the same and is a bucket load cheaper :D but I did get an N1 oil pump (thanks Slide)
but dont the N1's have a different blade design that aides in anti-caviation?
and bs its 'pratical', with everything on the motor, ur not gonna tell where u have an oil leak caus ull hardly be able to see the block! (with the engine in the car)
yes I went eagles the H beam ones there is nothing wrong with them many other people I know have used them before and not had any problems. And its not as if I will be driving the car hard I respect it too much to drive it unnecessarily hard.
Bloody Hell Shane, give it a rest, you take the piss out of everyone's car, parts or results and I have yet to see you in your own vehicle. So some people have "seen" your car, big deal. Was it running?? Did it lay down a quick quarter time?? Does it get good mileage??
You are young, so I have cut you some slack, but enough is enough. Get the unicorn on the road and prove yourself a capable steerer and then maybe you can cut loose on some of us. Until then, shut the fcuk up!!
u love ur haltech that much :D
it'll be on the street when its finished, until then i dont see why i cant talk crap and stir people up, caus in the end its all light harted fun, and if some ppl arc up then so be it.
im just sharing my view of it all, and if i didnt critisise (sp) things, people would go through with things thinking everything is all good, when it coulda been done another way, cheaper and/or better
You do nothing BUT critisise though. Your opinion is not automatically correct. You seem to think your vast years of knowledge have given you the right to tell everyone and anyone how they should build their car. If everyone followed your lead we would all be looking in our yard at our cars instead of driving them.
yes criticism is good but positive feed back is appreciated as it means somone has taken the time to modify their car from factory to better suit their tastes. Now this may mean that it doesn't suit your taste but doesn't give you free rein to shoot as many holes as possible in their setup. have a look how you present your arguments as sometimes they are percieved as a hostile rather than a gentle nudge.
I haven't got a massive bank account and have talked to many others to find the best setup I can that fits the bank balance and tastes. I eventually want to show my car as this has been an ambition of mine for many years.
what would you have done different with his engine anyway shane??
and what is wrong with eagle H beam rods??
i quite like a engine with a bit of bling on it, look scleaner and tidier, plus stuff like anodised oil caps etc add to visuals of the engine bay.
we are not saying that your opinions have to change or are not appreciated but they are exactly that your opinions. Other people will have different view points and different wants and needs and as a community we respect each others views whilst trying not to trample their ideas into the ground.
Well, you can change or someone will snot you for being a smart arse!!
I find that people like you either change or get ostracised out of the group. Get along or get out.
I'm not saying you will get belted and it won't be me, but your attitude sucks.
Back it up with some deeds or back off. Your choice.......
And Troy, you are too nice. Tell it like it is!!
eagles arent as strong as some others (like Pauter for instance) and u wont be able to rev them as high (well so ive been told)
lol so every 'smart ass' in the world gets snotted and gets sidelined from groups, yeah id believe that. maybe its ur attitude that needs looking at?
Fine, go ahead, my faults are an open book, but at least I try and behave as my peers would want me to.
That is what friends are all about. You gravitate to a group who are like-minded individuals.
Maybe you weren't so innocent when you got "mugged"????
    • Next on the to-do list was an oil and filter change. Nothing exciting to add here except the oil filter is in a really stupid place (facing the engine mount/subframe/steering rack). GReddy do a relocation kit which puts it towards the gearbox, I would have preferred towards the front but there's obviously a lot more stuff there. Something I'll have to look at for the next service perhaps. First time using Valvoline oil, although I can't see it being any different to most other brands Nice... The oil filter location... At least the subframe wont rust any time soon I picked up a genuine fuel filter, this is part of the fuel pump assembly inside the fuel tank. Access can be found underneath the rear seat, you'll see this triangular cover Remove the 3x plastic 10mm nuts and lift the cover up, pushing the rubber grommet through The yellow fuel line clips push out in opposite directions, remove these completely. The two moulded fuel lines can now pull upwards to disconnect, along with the wire electrical plug. There's 8x 8mm bolts that secure the black retaining ring. The fuel pump assembly is now ready to lift out. Be mindful of the fuel hose on the side, the hose clamp on mine was catching the hose preventing it from lifting up The fuel pump/filter has an upper and lower section held on by 4 pressure clips. These did take a little bit of force, it sounded like the plastic tabs were going to break but they didn't (don't worry!) The lower section helps mount the fuel pump, there's a circular rubber gasket/grommet/seal thing on the bottom where the sock is. Undo the hose clip on the short fuel hose on the side to disconnect it from the 3 way distribution pipe to be able to lift the upper half away. Don't forget to unplug the fuel pump too! There's a few rubber O rings that will need transferring to the new filter housing, I show these in the video at the bottom of this write up. Reassembly is the reverse Here's a photo of the new filter installed, you'll be able to see where the tabs are more clearing against the yellow OEM plastic Once the assembly is re-installed, I turned the engine over a few times to help build up fuel pressure. I did panic when the car stopped turning over but I could hear the fuel pump making a noise. It eventually started and has been fine since. Found my 'lucky' coin underneath the rear seat too The Youtube video can be seen here: https://www.youtube.com/watch?v=uLJ65pmQt44&t=6s
    • It was picked up on the MOT/Inspection that the offside front wheel bearing had excessive play along with the ball joint. It made sense to do both sides so I sourced a pair of spare IS200 hubs to do the swap. Unfortunately I don't have any photos of the strip down but here's a quick run down. On the back of the hub is a large circular dust cover, using a flat head screw driver and a mallet I prised it off. Underneath will reveal a 32mm hub nut (impact gun recommended). With the hub nut removed the ABS ring can be removed (I ended up using a magnetic pick up tool to help). Next up is to remove the stub axle, this was a little trickier due to limited tools. I tried a 3 leg puller but the gap between the hub and stub axle wasn't enough for the legs to get in and under. Next option was a lump hammer and someone pulling the stub axle at the same time. After a few heavy hits it released. The lower bearing race had seized itself onto the stub axle, which was fine because I was replacing them anyway. With the upper bearing race removed and the grease cleaned off they looked like this The left one looked pristine inside but gave us the most trouble. The right one had some surface rust but came apart in a single hit, figure that out?! I got a local garage to press the new wheel bearings in, reassemble was the opposite and didn't take long at all. Removing the hub itself was simple. Starting with removing the brake caliper, 2x 14mm bolts for the caliper slider and 2x 19mm? for the carrier > hub bolts. I used a cable tie to secure the caliper to the upper arm so it was out of the way, there's a 10mm bolt securing the ABS sensor on. With the brake disc removed from the hub next are the three castle nuts for the upper and lower ball joints and track rod end. Two of these had their own R clip and one split pin. A few hits with the hammer and they're released (I left the castle nuts on by a couple of turns), the track rod ends gave me the most grief and I may have nipped the boots (oops). Fitting is the reversal and is very quick and easy to do. The lower ball joints are held onto the hub by 2x 17mm bolts. The castle nut did increase in socket size to 22mm from memory (this may vary from supplier) The two front tyres weren't in great condition, so I had those replaced with some budget tyres for the time being. I'll be replacing the wheels and tyres in the future, this was to get me on the road without the worry of the police hassling me.
    • Yep, the closest base tune available was for the GTT, I went with that and made all the logical changes I could find to convert it to Naturally Aspirated. It will rev fine in Neutral to redline but it will be cutting nearly 50% fuel the whole way.  If I let it tune the fuel map to start with that much less fuel it wont run right and has a hard time applying corrections.  These 50% cuts are with a fuel map already about half of what the GTT tune had.  I was having a whole lot of bogging when applying any throttle but seem to have fixed that for no load situations with very aggressive transient throttle settings. I made the corrections to my injectors with data I found for them online, FBCJC100 flowing 306cc.  I'll have to look to see if I can find the Cam section. I have the Bosch 4.9 from Haltech. My manifold pressure when watching it live is always in -5.9 psi/inHg
    • Hi My Tokico BM50 Brake master cylinder has a leak from the hole between the two outlets (M10x1) for brake pipes, I have attached a photo. Can anyone tell me what that hole is and what has failed to allow brake fluid to escape from it, I have looked on line and asked questions on UK forums but can not find the answer, if anyone can enlighten me I would be most grateful.
    • It will be a software setting. I don't believe many on here ever used AEM. And they're now a discontinued product,that's really hard to find any easy answers on. If it were Link or Haltech, someone would be able to just send you a ECU file though.
