Service Advisor.
I deal with wankers who take touregs up the beach and:
a) wonder why they broke
b) complain about how expensive it is to fix
I can tell you right now, I miss doing property developments. We’ll see how long I last, until I go back to 6 - 7 days a week to play with other peoples money in property.
so your the wanker who stands out the front every morning and says il take your keys sir, thanks very much, we wont do anything to your car you dont want to happen, then do exactly the opposite lol charge them through the arse! lol
Yeah I’m one of those un ethical pricks out the front.
I’m on a salary package with monthly bonus and a commission % based on parts I up sell and labour on those.
Of course I say you need this, this and that. Tire’s rotated, Sir? New wipers? Oh an oil leak, we’ll fix you up with some new gaskets
*rings an hour later - Your brakes are farked, we'll fit new genuine ones*
ha ha, they see the suckers coming dont they, my mate took his wrx there, didnt buy it from there it was out of warranty, it was a 2000 model hatch, and he just asked them to test to find a problem and let him know, he came back they said his air flow meter was farked charged him $750+ he wasnt happy at all. i told him not to pay it tell them to take it off the car, they cant install something u havent approved. c**ts!
Edited by 85URK
HAHAH, yeah sounds like Mdore office alright... *giggles*
Wana buy a car care package for $2k :P
rofl i now mechanics who work there aswell, past and now. they just doin there job, but f**k me, the management have alot to answer for. anyway top gear i on later
yeah there are a heap of car nuts there, 3 or 4 skyline owners too.
The forman who runs the mechcanic side of things... runs an interesting system, already had a run in with him today. He may be big, but i'll still throw a punch. I dont value this job that much...
har har har, justcars are hopefully going to pursuit this old fart to pay for the damage to my car! no matter what i dont pay excess and i get it fixed even if they dont find the guy :P
watch out for this fiat driven by a old fart, you can see how close he parked (good job i thought it was suspicously close and snapped a quick couple of photos) hope if he doesnt loose his licence he at least will remember to drive with more care
    • So stock ECU does not like anything above 10 psi?  That Nistune one is just for "try" if it will be any different, I know it need to be tune for that. I know but YOU may know about these problem but i/we dont. They few little Skylines here let alone people who know anything about tham so that is why iam asking here
    • So now we have a radiator with no attachments whatsoever. It lifts up with a particularly tight spot between the drivers side air box mount and the lower radiator outlet, but if you've got this far you will sort that too. This is the lower mounts with the rad out so you can see where the rubber bushes go, it is a straight shot upwards Done! Assembly is the reverse of disassembly, with blood less likely to be shed.
    • Right, onto the second last trick. The Air Con condenser is mounted to the front of the radiator and stays in the car when the radiator is removed. There are 2x 10mm headed self tappers holding the top of the condenser to the radiator, remove those The bottom of the condenser is attached to the radiator with clips. You need to lift the condenser out of those clips and clear (up, then forward). f**ked if  could work out how to do that last bit with the front bumper on. I hope you can, and you share the trick.  Bumper removal probably deserves its own thread one day once I've recovered the will to live, but basically you need to remove the wheels, front inner guard liners (clips and 10mm headed bolts), the self tapper between the guard and the bumper at the rearmost point of the bumper (same as an R32 that bit), any remaining clips at the top/front of the grill, an absolute bastard design with a plate that holds the top of the bumper above the headlight each side (only 1 bolt which is tricky to get to, but the plate catches 2 places on the bumper and must be removed....carefully!) and push clips between the bumper and guard under the headlight. If you've done all that you will be faced with wiring for the fog lights on both sides and in ADM Q50 RS at least, 4 nasty tight plugs on the driver's side for the ADAS stuff. So, the clips at the bottom look like this on drivers side (looking from the front) And on the passenger side (also from the front), you can see this one is already out Clearance on both of these are super tight; the condenser needs to move up but the upper rad support mount prevents that, and the radiator can't move down far because it is (rubber) mounted. Once you achieve the impossible and drop the condenser off those mounts so it does not stop the rad moving, you are good to go
    • OK, next the shroud needs to come off and there are a couple of tricks. Firstly, there is a loom from near the passenger side headlight to the fans, coolant temp sensor etc and there is no plug to undo.  In my case I was OK to leave the shroud on top of the engine so I just undid the passenger side fan plug and about 10 of the clips which gave enough free wire to put it aside. The fan plugs were super tight, the trick I used was a small falt screwdriver to push down on the release tab, then a larger flat screwdriver to lever the plug out of the fan unit....be careful with how much force you apply! If you need to remove the shroud altogether for some reason you will have to deal with all the plugs (tight) and clips (brittle)....good luck. I removed all of the clips and replaced them with cable ties that I will just cut next time. Also, in the Red Sport / 400R at least, the intake heat exchanger reservoir hose is bolted to the shroud in 2 places with 10mm headed bolts; so remove them (the hose stays in the car; no need to undo it at the t fittings down at the radiator lower mount. Once you've dealt with the HX hose and the wiring loom, there are 3x 10mm headed self tappers holding the top of the shroud to the radiator; remove those.   The shroud then lifts out of the bottom mounts where it sits on the radiator, up and onto the engine out of the way. Simples
    • Ok, disregard my “rate them” comment, sorry for my unrealistic input
