i'm getting a 16k payout!!!!! i cant believe it!!! holy shit!!!!
no one is to ever bag out famous insurance again ok. there was so much dodgy stuff done with the purchase and i didnt even have the rego in my name yet and they paid me out!!!
i still cant believe it!!!
your shoutin us all dinner tonight then
now you can go off and buy that hair dressers car!!!
Mikeisahomo
repeat.... what are we buying me?
:devil:
That's awesome tho congrats on ze payout!!!
:devil:
you dont have to be on the rego to hold an insurance policy on the car...
thats awesome news :devil: actually if you're still after a mx5 theres a silver one (looks to be the first series mx5) for sale outside a house on some road in benowa (gc) near where im working this week (no idea on price but it looks clean, i could get the street name for you?)
what they found it?
no, agreed to pay me
hell yeah! i'll be there tonight! but i'm not shouting any of you dinner, still too broke. 3-5 days and the cheque will be here!
i'm still shaking like crazy
LOL mike u must be excited i would reply to your sms but doing it here is cheaper :devil: congrats on the payout :devil: guessing you'll set a decent amount aside for a good alarm/immobiliser for whatever you choose this time?
Its just a kent to get off. I have it off all I have to do is replace the gasket and reassemble half my car
i see
your being lazy, but i do know how you feel. i had the same trouble when i high flowed my turbo....
man the worst nut is the one on the dumpipe connecting to the back of the turbo the litttle one in the middel away from the block... mine was a diferent size, and also trying to put the water lines back on....
but yeah Andy i can sympathise with you, so when are you buying the high mount manifold :devil:
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
