I want to get Botox on my balls!! then i'll have smooth egg like balls....
then you all be like "wow you have smooth egg like balls" and you will want to kiss them :(
eggs over easy? better not get too violent or they'll get scrambeled... or if you'd had indian the night before they might get yellow curried
In that case I can guarantee you that our response wouldn't be quite what you are expecting... ;)
ohh.. tounge.....
But i'm a shy individual who doesn't like to socialise. How can I get around this?
Go bra less.. it will boost your confidence as well as a free face lift!!
purchased from a chicken farm off a guy strangely resembiling phatboi lee, they get stored in a special box thats been in the family for years :)
if you keep them in milk... Ooopsss i siad to much :(
Ready Anna?
READY!
*sings*
We're the Annateers
You can be one too
'Cause being like Anna is the thing to do!
Any other name is not the way
Hear what Captain Anna has to say!
"The Power is Yours!"
Ready Anna?
READY!
*sings*
We're the Annateers
You can be one too
*listens for this 'captain anna'
soo who is lucky enough to be healthy in mind AND body to be going to dinner tonite? i guess either option would be sufficient...
i'm coming but healthy maybe not..
Ready Anna?
READY!
*sings*
We're the Annateers
You can be one too
so so random!!!
Oh Anna Bannana you make me lool till i pee a lillte...
OMFG
I just threw up in my mouth a little.
Just Swallow it.. its good for you.....
oh wait..... that shounds oddly familiar....
Oh they're playing Anna's Favourite song on Nova!!!
skyliners = healthy minded & body?
nahh man, u got the wrong forum :)
ahh crap, i thought this was boostcruising where everyone is 24yo, has 6 packs and a 2ft schlong
oh wait, on that forum they're 2.4yo, have 6 packs of udl and are 2ft high thanks to several inbred associated genetic disorders.. :( my mistake
And guess what...
There is only one other person cool enough to be an annateer. I'll give you a hint.
Her name starts with A, ends in NNA
AnnitaboshicovariariNNA the russian table tennis champion?
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
