i'm gonna get everyone here on the emospace band wagon
fat chance of that happening!
there is no such thing as a cool myspace, your all emo's!!!!
morning whoretown.... teh zac is still feeling ill! :no:
:no: awwww poor isaac. well i'm feeling great, if that makes you feel any better
:laugh:
coffee time :laugh:
Bender - "you look a little wound up buddy, and your face is greasy, reeeaaaalll greasy. You been up all night"
Fry - "of course i've been up all night not because of cafiene but because of insomnia i couldnt stop thinking about coffee i need a nap *falls asleep* COFFEE TIME!!!!!!"
hey mike that mate of yours that tired to get the address of that guy a few weeks ago, how was he going to do it? i've heard you can go to the transport dept, say some bs story that car with plates XXX-123 reversed into me and drove off, and they give out details?
mmm leftover coldrock cookies and cream mixed with crunchie and The land of goat sphincter rings delight
strangely that sounds kinda nice :laugh:
i know what i want for lunch.................no not really, but i am hungry now :no:
yeah, i dont know exactly how but he said he would look into it. i didnt really want to ask what channels he used to look, knowing him, it wasnt dept of transport :no:
this is the only pic i am putting up of the car i want. not gonna give you much idea really, except what the engine is.
remember though, i did say it was differnt to what i was thinking.
Edited by lilmike86
strangely that sounds kinda nice :no:
i know what i want for lunch.................no not really, but i am hungry now :O
yeah it is :) i got some last nite to help my sore throat!
well its another avenue to take, so i'll give it a go when im upwardly mobile - cos if i can get it... some retribution will sure be sent his way i think a couple of lawyers, one to 'sue' his face, the other to 'sue' his car :laugh:
i see no pic :laugh:
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
