This thing is hideous!!!
This is the new Mercedes Benz SCL600 No steering wheel, you drive it with a joystick. No pedals either.
that car never would of went into production.
it'd never be seen here in australia as it doesnt meet any of our ADR standards
lol
no, i was actually working for a bit there :P shame, i know
dont lie! *backhands anna*
sorry, what now? i sorted missed all that :D
well put
no rush
we`ll be here all day
Talk about horny little geek boy.....
Miky the master of one handed typing....
they should change the name of this thread to "horny little geek boys..... Oh look its a girl!! "
fark in hell its just Pussy!!
your puttin that pussy on a pedestal!! :P
It's flash, cutting edge and no doubt costs a packet... but I just can't bring myself to like it.
I bet it doesn't even have a "pop clutch" button, or a "fullii sik rollbacks" mode.
Mehning
morning
be back laters :)
please dont :P
:P
your puttin that pussy on a pedestal!! :D
WTF? where the hell did all that come from? and what the crap? dude, i've been out whored the past week, i'm not even on the top 10, its all anna :P if i get horny, i'll just do some work :)
you feeling ok lee, or did linh refuse you sex again?
morning
please dont :P
:D
always refusin dude.
she wants to go back home
but cant cause she maxed out lee's credit card.
WTF? where the hell did all that come from? and what the crap? dude, i've been out whored the past week, i'm not even on the top 10, its all anna :P if i get horny, i'll just do some work :P
dont worry about me i'm prolly the only one in her getting Frequent (& Good) sex....
its just funny.....
to see how you all react to a girl being here i think you should all go join BC or Cb cos thats exactly how they act over there....
have some integrity pls people...
once again its just Pussy...
its just funny.....
have some integery psl people...
um, lee, this is no different to how i normally act. if anything, i'm actually quieter. i'm down to less than 40 posts a day. seriously WTF! i used to be on 140 a day.
are you referring to me or others, i'm confused here :P
Edited by lilmike86
while we r at it, can we pelt ice cubes at him too?
i`ll organise one of those tennis ball machine things to do it
:P
i was thinking concrete filled tennis balls
its ok everyone, lee is on his period
oh, his manrags, well, that makes more sense then
you and others...
i didn't say how much you post its about what you post.....
man you should read over your post.....
basically its all of you waiting on this Anna to post then ignoring everyone elses post and just trying to get her attention its quite.....
pathetic
but meh its your choice.....
right
lee's lost the plot
time to get him a cold bucket of water and throw it over his head
John needs to give lee the drugs he's on.....
you and others...
pathetic
if i wanted her attention i would do a troy. dude this is me, if i wanted something, i would be making a move. i wouldnt be spending time online to get someone, thats just ghey.
you should know that whoretown is all about sarcasm dude, that and all the gay jokes dont work on women. take a step back lee and stop being so serious. we are all here to make the most of work, by not doing any.
i have acted the same around everyone, if you think otherwise then thats your issue i guess.
go have a bat lee, you'll feel better :P
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
    • OK, so regardless of whether you did Step 1 - Spill Step 2 - Trans pan removal Step 3 - TCM removal we are on to the clean and refill. First, have a good look at the oil pan. While you might see dirty oil and some carbony build up (I did), what you don't want to see is any metal particles on the magnets, or sparkles in the oil (thankfully not). Give it all a good clean, particularly the magnets, and put the new gasket on if you have one (or, just cross your fingers) Replacement of the Valve body (if you removed it) is the "reverse of assembly". Thread the electrical socket back up through the trans case, hold the valve body up and put in the bolts you removed, with the correct lengths in the correct locations Torque for the bolts in 8Nm only so I hope you have that torque wrench handy (it feels really loose). Plug the output speed sensor back in and clip the wiring into the 2 clips, replace the spring clip on the TCM socket and plug it back into the car loom. For the pan, the workshop manual states the following order: Again, the torque is 8Nm only.
    • One other thing to mention from my car before we reassemble and refill. Per that earlier diagram,   There should be 2x B length (40mm) and 6x C length (54mm). So I had incorrectly removed one extra bolt, which I assume was 40mm, but even so I have 4x B and 5x C.  Either, the factory made an assembly error (very unlikely), or someone had been in there before me. I vote for the latter because the TCM part number doesn't match my build date, I suspect the TCM was changed under warranty. This indeed led to much unbolting, rebolting, checking, measuring and swearing under the car.... In the end I left out 1x B bolt and put in a 54mm M6 bolt I already had to make sure it was all correct
    • A couple of notes about the TCM. Firstly, it is integrated into the valve body. If you need to replace the TCM for any reason you are following the procedure above The seppos say these fail all the time. I haven't seen or heard of one on here or locally, but that doesn't mean it can't happen. Finally, Ecutek are now offering tuning for the 7 speed TCM. It is basically like ECU tuning in that you have to buy a license for the computer, and then known parameters can be reset. This is all very new and at the moment they are focussing on more aggressive gear holding in sports or sports+ mode, 2 gear launches for drag racing etc. It doesn't seem to affect shift speed like you can on some transmissions. Importantly for me, by having controllable shift points you can now raise the shift point as well as the ECU rev limit, together allowing it to rev a little higher when that is useful. In manual mode, my car shifts up automatically regardless of what I do which is good (because I don't have to worry about it) but bad (because I can't choose to rev a little higher when convenient).  TCMs can only be tuned from late 2016 onwards, and mine is apparently not one of those although the car build date was August 2016 (presumably a batch of ADM cars were done together, so this will probably be the situation for most ADM cars). No idea about JDM cars, and I'm looking into importing a later model valve body I can swap in. This is the top of my TCM A couple of numbers but no part number. Amayama can't find my specific car but it does say the following for Asia-RHD (interestingly, all out of stock....): So it looks like programable TCM are probably post September 2018 for "Asia RHD". When I read my part number out from Ecutek it was 31705-75X6D which did not match Amayama for my build date (Aug-2016)
