Morning darling ones :(
Andy, you interstate post whore :wave:
morning karen, how ya going this fine thursday morning? ;)
P.s dammit, thats it ive had enough of this stoopid flood control bullsh!t *sends donation*
Morning darling ones :wave:
Its the only way to fly
ur cruise is on tomorrow, so get the fark up and finish ur car! ;)
how was that? :(
Not gonna happen, No clutch till Saturday
>An old couple who hadn't celebrated Halloween in a long time decided to
>dress up and go out. The old woman went into her bedroom, stripped naked
>and tied a lemon between her legs.
>When she came out, the old man cried, "You can't go out like that!" She
>said, "I can go anyway I like and so can you."
>Whereupon he retired to the bedroom and came out stark raving naked with
>a
>potato tied to his tally whacker.
>The old woman says, "You're going out like that?"
>He replies, "Yep, if you can go as a sour-puss, I can go as a dick-tator."
well that was a total waste of my energy and good intent, the stupid donation thing doesnt allow direct transfer. how stupid is that? idiots ;)
bawahahahaha
shane, pm me ur bne-site address there
so i can send this cd to u in the internal mail
    • roof rail delete used to be a thing, they were made locally for a while too
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
