Everyone go order a calendar -
http://www.skylinesaustralia.com/forums/in...howtopic=154015
i run this at a lost, i aint going to be happy.
specially after the amount of hours i've spent doing this project.
why dont you wait until you have at least 75% of the calenders paid for before you order them??? Otherwise its a big risk imo.
bit of an understatement :O i believe farking hot would best describe that. very unique as well. thats in the states isnt it
yea its in the states. Its hot but yea, its one of the only hot ones i can find and I reckon it would be expensive to get someone in Aus to fabricate a kit..everything i want is too expensive and is200 with a 1/2j, a 3000gt with nice kit and minor mods...everythings too expensive arghhhh!!!! I guess its the price of wanting something sorta unique!
thats pretty much what im doin.
placin orders now while im still doin the artwork will make things flow alot better.
and once you see the layout of this calendar, you'd be gobsmacked and wont be able to wait until next years one.
this calendar is pretty much designed to make heads turn :O
are you going to post some pics of what its going to look like?
:O
ahhh she's back!!! *runs and hides*
hi anna ;)
i know what you mean. the kit i want for my next car is going to cost me 5k just to order it from japan, plus an extra 2k to fit it and paint it (thats through my friend as well, 1k for paint job) then again, it is a wide body
so which one of you girlies are coming to night???
you know you arranged it so you need to count the numbers and make the booking still mike....
i'm not going to get a chance lee :O i've got to prepare notes on the performance of my branch and shit. i only have 1hr to do that in. then i gotta drive out to hendra to go to the meeting ;) its bullshit, it really is :O
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
