geez mike, you not trying to rack up a post count are you?
no, this is me when i'm bored
theres no interesting topics in qld either!!
i know, sucks. why cant you people be interesting!!!!
last time we just harassed boostlosing, but got in trouble :) when they found out
harrassing boostlosing ftw...they suck ass!
hehe yeah, i had 8 reports on me that day :) marc wasnt impressed but he didnt get me in trouble ;) it pays to sleep be friends with the president
