LOL LUCKKKKKKKKKKY!!!
AND I DON'T AGREE WITH THAT IN THE WORKPLACE!!!
that will make no sense if u haven't watch the UK version of The Office
ha ha ha
Yeah i'm good... my mouth hurts from chewing too many minties :P BUT MY MUM'S COOKING SPAGHETTI SO EVERYTHINGS COMIN UP MILHOUSE!!!!
How bout u?
minties + spag bowl ? interesting...interesting..... (yuk!)
i'm good, i'm working at the wesley this week doing random stuff. Just sent the company $81 worth of gateway toll reciepts they gotta pay me back for :D
and NOONE LIKES MILLHOUSE!! (i loled, that episode was on recently)
as for the mintie situation i have none, but i'm about to fire up the oven for dinner...on tonights menu is the choice of
-chicken ravioli
-pepper steak, rice and salad
-garlc chicken kiev, rice and salad..
CHOOSE WISELY :blink::P (cos i dunno what to eat)
what were the dead sparrows doing in the sky?
And if I recall your reaction was far more favorable last night away from prying eves
prying eyes dont worry me, its the one eyed one i dont wanna see!
i'm good, i'm working at the wesley this week doing random stuff. Just sent the company $81 worth of gateway toll reciepts they gotta pay me back for :P
-chicken ravioli
GARLIC CHICKEN KIEV!!!!!!
GARLIC IS THE SHIT!!!
ha ha ha is there something wrong with that?
haha must be a territorial thing.. my dogs back home used to do that, one would drop it on the lawn, the other comes along in a "oh hell no you just didnt crap on MY lawn!" then eats it in a "yeah bish what u gunna do now, wheres ur shit now dawg? yeah!"
ps: i'm bored!
ps: i'm bored!
Ok please stop talking. You're making my brain hurt just reading that.
Miss boost. NA is for chumps.
As i recall you can get good results from turboing the 2JZ-GE (rather than a 2jzgte convo), there was a couple of sites about it.. american pretty sure
ps: i'm bored!
ha ha ha sounds "interesting"
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
