you really should eat something for breakfast anna, its really not good for you to skip a meal like that.
blah blah blah, it stops me from getting fatter LOL
so SHUT IT!!!
There's just nothing really that yummu for breakfast...
OHHHHHHHHHH BRAN! YUMBO!!! LOL
Although I do enjoy pancakes ;)
I'm out now you poofs and Im bak so f*kken wotch urselfs. Skyline poofs.
I ain't nowuns biatch.
maybe you should get back in your honda and push it outta here ;) i think your bf is calling for you
Whatever bitch-tits, go back in ya box.
lol hahahahaha she'd prob own you mate, but your welcome to try. anna is addicted to sodemy so.....have fun with that
*sits back with popcorn*
so SHUT IT!!!
eat pancakes then. also, you will actually gain less weight if you eat more meals each day, rather than less but larger amounts :)
Let me see!!!!!!
Today so far i've had 3 minties
BAHAHAHA
I usually don't eat anything till 12, so I feel like yacking...
Shane can I borrow your face for a sec?
*grabs shanes head and projectile vomits on his face*
Cheeeeeeeeeeeeeeeeeeers
being called a butt pirate ------>;) <-----vomiting on shane
b!tch ur gonna die :)
an wheres my good morning? ;)
Now you see this is the problem with youth in today's society. You all assuse I am a criminal and have obviously done time fo son of rajab knows what. Not one of you have stopped to check my join date which is before all of you. You wonder why we have such a strong new-school/old-school rift without even asking yourselfs why.
On another note, stop making grammar a lost are.
poofs.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
