you really should eat something for breakfast anna, its really not good for you to skip a meal like that.
blah blah blah, it stops me from getting fatter LOL
so SHUT IT!!!
There's just nothing really that yummu for breakfast...
OHHHHHHHHHH BRAN! YUMBO!!! LOL
Although I do enjoy pancakes ;)
I'm out now you poofs and Im bak so f*kken wotch urselfs. Skyline poofs.
I ain't nowuns biatch.
maybe you should get back in your honda and push it outta here ;) i think your bf is calling for you
Whatever bitch-tits, go back in ya box.
lol hahahahaha she'd prob own you mate, but your welcome to try. anna is addicted to sodemy so.....have fun with that
*sits back with popcorn*
so SHUT IT!!!
eat pancakes then. also, you will actually gain less weight if you eat more meals each day, rather than less but larger amounts :)
Let me see!!!!!!
Today so far i've had 3 minties
BAHAHAHA
I usually don't eat anything till 12, so I feel like yacking...
Shane can I borrow your face for a sec?
*grabs shanes head and projectile vomits on his face*
Cheeeeeeeeeeeeeeeeeeers
being called a butt pirate ------>;) <-----vomiting on shane
b!tch ur gonna die :)
an wheres my good morning? ;)
Now you see this is the problem with youth in today's society. You all assuse I am a criminal and have obviously done time fo son of rajab knows what. Not one of you have stopped to check my join date which is before all of you. You wonder why we have such a strong new-school/old-school rift without even asking yourselfs why.
On another note, stop making grammar a lost are.
poofs.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
