i'm sick of living here
I wanna go live somewhere else, and my friend just went to New York and now I wanna live there!!!!
Or California..... Someone come with me!!!
I'm in :laugh:
good morning sweetie...
:laugh: i swear some where mike said he was good at DDR but he was really bad playing by himself :laugh: must be the Virgin in him..
:laugh:
See atleast i'll admit i'm bad LOL
Oh & I have to say, Anna & I were SMOKIN last night!!!
flight attendant
HA HA HA HA HA HA HA HA HA HA *wipes tears from eyes*
your not seirouse are you ? :laugh:
Passenger: miss can i get another pillow?
Anna: Get your own dam pillow you lazy barstard. its not like you have anything better to do. if your gonna ask me for anything else i'm gonna stab you.
I think i'm going to move to America.....
I moved to corona del mar/ Huntington Beach for a while, best move ever. I wish I was back there, if getting work, and then a work visa was easier I’d be there again tomora.
Edited by Nismo_Boy
flight attendant
interesting...i guess u'd be able to see a fair few palces
dude she wouldnt have anything to stab them with :laugh:
BAHAHAHAHAHA
shut up ass face!!!
I CAN be professional when I want to, I just choose not to be most of the time... :laugh:
I'm going to get a job there now just to prove you wrong LOL
BAHAHAHAHAHA
shut up ass face!!!
thats all well and good, but could u last a ~20hr flight?
i rekcon u'd break under the pressure of not having a go at some1 for ages :laugh:
dude she wouldnt have anything to stab them with :wave:
a fork will do....
BAHAHAHAHAHA
shut up ass face!!!
I CAN be professional when I want to, I just choose not to be most of the time... :wave:
Talking about Forks, hows about joing the might high club then :O
Anna you know you want to :laugh: dont tell Linh :laugh:
i rekcon u'd break under the pressure of not having a go at some1 for ages :huh:
:laugh:
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
