Allright ladies i'm off to pick up linh.....
i will see most of you tonigh hopefully....
so who wants to stir up john about the calender tonight??? :)
man he's been hard done by Col..... he asked me to put an anti col thread up for him :)...
I've never even meet the man....
OTAY BYE TTYL!!
john'll be doing the stirring tonite :ninja:
how is u gorgeous girl?
Yeh not bad. I'm just eating some home made sweet and sour pork. YUM! Waiting for Andy to get home and then hopefully plan our evening.
How be you?
How be you?
i'm off kiddies!!
:sick:
talk to ya's soons!!
i'll see BOTH of you tonite
kbye
:ninja::)
*rubs face* :) dam Woman just wanted a little squizz.....
i'm with you mark...
but my GF never shows off in anything...
when she wears a bikini she has board shorts and shirt as well :) she says she's being careful for sunburn...
tis the suxor.....
haha same with my GF..
she wears boardshorts and a singlet that goes see thru when wet and it sticks to her like a second skin.. :ninja: .. pointless. but its cool how she dnt want to show off to others but only me.. makes me feel warm and fuzzy inside. SPECIAL PREVILAGES
Edited by markimak
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
