cheers col, Im not concerned about the plates, Just, if the club did fund them, id rather have my club fee go into something better, i understand that not alot of clubs have then,, but to be honest the calendar would be alot better...
thats my 2 cents...
ha ha oh well, are u gonna still be a member of the club once u move up here issac?? u can take me to some meet ups in brisbane on weekends sometimes lol
whats wrong with driving your ownllazy ass down :)
but yeah, i'll still try make the odd tues dinner/cruise or whatever...when i'm not working nights/on call/in bundaberg :happy:
i will drive my own ass down, just would rather some 1 to travel with, but i wont be going on weeknights.
i usually only attend cruises etc sometimes. a few times a year.
yeah sounds good, white 33's FTW :happy:
bryn in his silver 34 FTL :)
thats my 2 cents...
Not quite sure where the clanader is atm as im out of that loop.
But i do understand that John has "told" me not to comment on it as he thinks im out to destroy him.
So in saying that i have nothing to say... :happy:
**RESULTS OF SAU QLD DYNO DAY
Owner : daz
Car : pineapple
Result :256kw @ 15psi (pineapples squeezed internally)
:happy::):)
cCome on, the pineable will make at least 350 at the wheels
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
