im talking to Josh btw, coz most of you probably won't know what thread im on about...
I’d rather not comment. Neil changed the Logo to use for TK, Aaron used the same one Neil had changed. He could have atleast changed something.
yea i know, i'd posted heaps of stuff in there about it...but yea....its all been removed...i don't know why....obviously "off topic" however i've seen things a lot more off topic let go.
SPAM!
How is everyone?
Just a quick question
Why is there so much junk on the forumns atm?...
Im bored shitless here, the only thing i can be entertained by is meaningless questions people ask for opinions, these were posted on topic with no real thought and all they get from posting these is a genuine reason, after that, the case is closed, everyones agreeing, or agreeing to dissagre, then theres nothing left to say.
I guess im having a little bitch about this because i can only relate to these types of topics because i do not have a car, nor the knowledge to help people out with thier car issue topics.
:D thats my two cents *breaths out happily*
Any one want some pie? :)
Edited by ze_flexy_1
SPAM!
How is everyone?
nah you're right and the answer your looking for is they are n00bs with no idea. Half of the topics are useless and the other half are in in the wrong freaking section..noone has any idea how to use the search function either as it appears.
Im going to try hey :D...... hate missing events......work is so gay, currently looking for a job in the retail/fashion industry that goes more further than weekend shit casual work..
Anyone no anyone who needs a hand in a fashion store?. Beauty therapy salon?
hehe doesnt hurt to ask :)
nah you're right and the answer your looking for is they are n00bs with no idea. Half of the topics are useless and the other half are in in the wrong freaking section..noone has any idea.
u so wana be a mod, you know they never make u a mod, seeing the will never make me one as long as sau is around hahaha!
you're spelling and grammar sucks, but no I don't so wanna be a mod lol.
you'd be a dodgy mod rofl...ban's to people left right and centre hahaha.
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
