i did that for Mark already lol, almost go done by a coppa :kiss: and then launched it at the cop shop lol so silly :P
haha wat a night lol.. yeah i knw wat the Rb20 sil has got.. its not bad..
If you're such a seedy pervert now I don't even wanna see you when your an old azn man......
:P
oh perverted hermit like in naruto ahaha.. u gonna write dirty novels?
Yuppers/ One xtra large for my brain filled head and one small for your empty head.
cum filled head noel?
haha thanks matey.. hope she fits well.
u'll be complaining ur sick soon :)
no no i mean at the drags mate, get a number on paper!
last time i ate ther i got sick..
and that $5 meal is supposively a waste... :rofl:
Josh is being a Homo again.....
some bullshit about calling all of us noobs and that we dont know who to organise shit...
we should falme the barstard.....
lil silver spoon fooker is calling all of us pook homeless bums
sif i ever drag my car....... lol to embarrasing
I know you love my silky smooth ways Anna...
wat do u think it will run?
she better not blow up on me..
Lee you're about as smooth as Sandpaper
ahah thats gold..
YES WHORETOWN IS ALIVE AGAIN..
what thread is this in????
Is it wrong to give out your business card to a chick, if your trying to tune her.
Seems sleazy, yet funny at the same time.
Discuss.
It all depends on how attractive you are ...
To be honest as long as your hot as, it's never sleazy bahahahaha
If someone is hideous it's sleazy and wrong..
Oh you suck.
I didnt mean about me fool!
lol then its very sleazy and wrong for josh to do it....
I think I'm pretty hot.
You have mym myspace, go finger yourself over me or something?
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
