quote name='33NIZ' date='1 Mar 2007, 02:40 PM' post='2945053'
dont bore me with insults regarding mummy or daddies boy....they are both
1)lame &
2)old
Only to yoy. We quite like them
learn how to quote or don't bother trying.....oh n00b's are so boring.
dumb much? :P
or u a mummies boy?
go to this website....www.boostcruising.com...as you've stated in your sig, they are at about the same intellectual level as you.
Careful you don't get too roasted there...as they don't like n00bs like you either.
careful you dont get too roasted there...as they dont like n00bs like you either.
no need to take everything to heart matteh
look even josh admitted he's a daddies boy, why's it soo hard for you?
Nothings taken to heart shane...lol
Is it because I have money and drive a nice car i'm a daddies boy? Maybe I should buy a 89 GTR leave it unrunning in my garden out the front of my unattactive apartment, would that make me a successful independant?
I only ask as you because being a n00b and all, your opinion does mean quite a bit to me rofl.
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
    • In my head it does make sense to be a fuel problem since that is what I touched when cleaning the system. When I was testing with the fuel pressure gauge, the pressure was constantly 2.5 bar with the FPR vacuum removed. When stalling, the pressure was going up to 3.0 bar (which is how it should be on ignition).
