Hrm...wish i could leave at 4pm...the CEO here announced a staff meeting at 4pm today...who the fark does that on a friday :O
PS. that's a rhetorical question
Usually one that is trying to crack a date for friday night.
least I'm not at work
sif a 16 year old pimply faced key bored warrior works.... of course your at home its past 3 and shools been let out....
oh and :O at least i dont eat cock
Fark i'm bored.. bored enough to give this looser a good ebashing....
Hey Noel, bum sex?
Hey Noel, bum sex?
Nah, still too sore from last time. :woot:
i need to have some fun... i'm so farkin bored.....
any one have any chicks on msn i can chat to be them ugly or hawt i dont give a f**k sif i am ever gonna meet them just want to flirt with them and get them to agree to suck my balls.... you know just incase i end up in the dog house with the misuss :O
Nah, still too sore from last time. :huh:
lol i told shane not to use that butternut pupkin :woot:
plus who the fark joins at 4:35 am :(
Get back to work Bitch.... ha ha ha i think i scared him off lol :O
Oh damn, was I a minute too early? Too late? Do I get a special tag if I create an account at the 'right' time? Argh, I'm missing out on so much
most 'normal' people join at u know, times when 'normal' people are awke, like say ~6am or afterwards? then again, u musnt be 'normal'
P.S ill warn u now, i cant type/spell properly, plus i dont give a shit :O
Oh god the big bad forum guy is ebashing me with his giant ebat and huge postcount. What the hell do I do?
Oh right, I don't care.
<fark off stupid flashy thing>
lol your still here.... what huge post count? you are sadly mistaken i dont have a huge Ebat i have a huge Ewang and will proced to E turky slap you.....
Farking Junky up all night shooting up.....
eat a dick another dick
:O
:huh: i really dont have a come back for that :woot:
Only thing that scares me is your F5 ability. If you could hook up your F5 key to a drivechain you'd outrun everyone.
:O what the f**k are you on mate? man the drugs stuff up your brains....
go back to your cock flavoured corn things.... narchos.. that them......
I think the nachos have drugs, I see this white creamy liquid all over them, oh shit it just exploded all over my face. Guess they really were cock nachos.
lol what a looser you just :O your self? have you no self respect or do you have a very low self esteem?
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
