ummmmmmmmmmm it's for a photoshoot, that i'm gonna go with 2 gf's too...
No pics yet cos i haven't gone bahahaha
but it's thru platinum photography and it's gonna be HOTTTTTTTTTTTTTTTTTTTTT
OMG I won of those a while back. You think you've won, but you actually haven't. You get your makeup and pics taken and then you have to 'choose' a package of pictures to take home. Those pictures however, have to be paid for :no: I hope yours is different, cos while the pics were AWESOME, the price wasn't.
Anna
OMG I won of those a while back. You think you've won, but you actually haven't. You get your makeup and pics taken and then you have to 'choose' a package of pictures to take home. Those pictures however, have to be paid for :down: I hope yours is different, cos while the pics were AWESOME, the price wasn't.
Anna
nah yeah I know them ones... Talked to the chick today and it didn't seem like it
BUT i'm not definately doing it yet... i''ll see what comes of it..
AWWWWWWWWWWW ANNA U SUCH A BIG SISTA!!!
:no:
CIAO! CIAO!
BAHAHAHAHAHA
Edited by LIL34
shortend because your responses were so lame they need not be repeated.
If that's all you have i'll leave you alone now, I assumed you were in yr12 but your lack of witty responses indicate that you are clearly in a grade much lower than that...perhaps you should try flaming people on something like the humphrey forum?
http://www.humphreybear.com
(this should keep you occupied for a while)
andy has turned pink on us.....
LOL nah. I'm now signed in as me. Hooray!
AWWWWWWWWWWW ANDY'S U SUCH A BIG BROTHER!!!
:down:
CIAO! CIAO!
Oh good :laugh: Bye byes *kisses boob
oooh Anna :no:
how was school today?
I just had 2 kiwifruits for afternoon tea. They were the awesomest!
School was fine mum :ninja: I had linguistics today. The study of the science of language. I thought it was going to be ergh, but it was fun. I have a cool lecturer, his name is Abass, pronounced 'ah bus'. He is funny and makes us debate each others thoughts. But you'll never guess who is in my class... GRIFFITH BOY! The dick that wore all the griffith merchandise to O week. I have been lucky to not have him in any of my classes, but I do have him in this one. Grrrrrr. He thinks he's heaps clever and WON'T SHUT UP!
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
    • No. I think it might be the AFM. Hence the use of the terms "swaptronics", which implies the use of swapping out electronics for the purpose of diagnosis. It's about the only way to prove that a small/niggling/whatever problem with an AFM or a CAS or similar is actually caused by that AFM/CAS/whatever. A known good item swapped in that still gives the same problem is likely to be caused somewhere else. They're all the same. Spraying AFMs with cleaner is an each way bet between cleaning it and f**king it.
    • Oh wow! This might actually work amazingly. Do you know the ratio of the diff? I was told the only thing you need to make sure of is if the front & rear diff ratios are the same. Ours is a 4.083 Thanks!
