That would be the best option.
Noel, you need some 18x10 and 18x11 - 16 offset
be a man
say no to + offset
I had dish once....I had to remove them because I could not handle hearing another prepubescent voice go AWWWWWWWWWWWWWW SIK DIIIIIIISH :no:
wtf are jdm yo wheels. wheels were not high on my priority list just yet. only bought these cos they were farking cheap and half bling.
Japanese Domestic Market......they fit and are light
Crap local ones don't cause all our local cars don't have brakes
werd. tool at tyre shop tried to tell me i had gtr brakes thats why they wouldnt fit. sigh
that was me when i saw the dissssssssssshhhhh on your 33. :no:
thats why those wheels are on the unloved car now....everyone couldnt get past the dish, It annoyed me that the cheapest and shitteset thing on the car got all the attention!
what price on those cheapest shittiest things? :no:
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
    • Legend. I ended up finding the facebook account of the owner of the first car i sent but sadly he deactivated the account. I think you’re right in saying it’s some sort of well done custom job. Really appreciate your help anyways.
