wtf.. lol i got a job lol.. im studying too.. opening doorways to my future.. ok lets race first one to own a 07 GTR wins..! do u have cert3 mech and cert3 finacial service cert3 accounting? no u got senior cert by the skin of ur teeth :)
ok as soon as i knw who will come 5ppl or more than ill organise!..
sick, u've got 3 pieces of paper, want a medal? or a chest to pin it on? :O
the 07 (08 it'll be in aus) is an ugly piece of sheit, plus most my money's going into my current car
shane lick my nipple..
hi grandpa u excited.. i ahevnt run a car down the strip in 2 years :O
first and last was a week after i got my GTiR pulsar.. MINI GODZILLA..
Try 22 years pupper. My last run was a 13.4 in a ht 350 monaro. big yellow monster we called the mango. loved that ride.
sick, u've got 3 pieces of paper, want a medal? or a chest to pin it on? :(
and wat do them pieces of paper open up shane.. GET AN EDUCATION!.. ahaha
y spend money on a GTR when u can spend money on other peoples car... ahaha wanna blow my head gasket?
22years.. ur gonna have a heart attack tomorrow with all that adrenalin..
hahah u wait until u see it little man :(
    • I can get more photos of it here soon and I plan to make a thread detailing the process. I received the car this way and it sorely needs refinishing. That is probably the most appealing photo of it. Up close it is fading, cracked, and needs to be re-glued. Depending on their condition I'm on the fence between refinishing or making a new set.  Another angle hiding the pimples and razor pumps
    • According to this thread the RS4V with build plate RC40 comes with the R200 diff @ 4.083 ratio as well (mine has said RC40 denotation). We may need to check if the axle stubs are the same pattern as well. The auto subframes have longer axles. However I think yours being a later Series 2 as well, we should have the same bolt pattern for the diff stubs. Unless your upgraded rear also has upgraded axles. Either way, I would not be opposed to pulling the covers to check so I can inspect that  fancy rear core  Also I don't have HICAS. I don't believe that should change things but I hope the people here with heaps more experience than me can correct me if I'm wrong   Let me know if you want to attempt to make this work and I can get some pictures of mine from under the car.
    • It's not that straightforward. For example I have had this code because my ignitor/power transistor wires were unplugged. It knows something is wrong but has no idea what it means. If you want to actually diagnose this I recommend following the service manual flowchart for code 21. Ohm out the harness, coilpacks, inspect the ECU, etc. And again, it's entirely possible for there to be no problem at all but if you're running a different coilpack it'll trigger the code because it doesn't like what it sees.
    • If it (the code) wasn't still current, it should have gone away by itself by now. No, nothing it 10/10. But it is quite likely. Everything else to do with the ignition could still be responsible (which is wires and connectors). The car is an old piece of shit now, so all the wires and connectors are also old pieces of shit.
    • Lock me in mate, although I'm not sure if I'll be heading up from Goulburn or down from Sydney, either way, return will be back to Goulburn
