I want to buy a cheap dirtyish s6 rx7 with a blown engine or something then import a race/rally one and swap everything...
if only you could find one i guess.... that is the biggest problem. no one would sell one just as a shell they arent like skylines, on every second street corner.
Yep, they are rare, but they do come up from time to time, just got to have the cash handy and be patient. I'm not usually good with the latter. Hence why I don't own an rx7. Maybe sometime soon i'll switch back to a modified car, when I start to miss all the police attention.
sounds like a spirit rs edition most of those features are factory :( if it is it has 3mm apex seals and improved turbo setup they are the most powerful rotary ever built for mass production by mazda
yeah i dont get police attention but mine isnt really modified much. exhuast, suspension and wheels thats it. but i will eventually until i get sick of it and sell it off for 8k less then what i payed for it originally....that is what happens these days isnt it.
Yeah, the depreciation on imports has been rediculous over the past year or so...
this is what it is.
http://www.ultimatecarpage.com/frame.php?f...amp;carnum=1109
R33gtst have to be the most common import into australia now i reckon.
but the problem lies with ppl importing cars to sell just to make a quick buck, and selling them for like 11K etc when clearly they are worth more then this, how can ppl compete with those prices.
and australian domestic market cars like holden, ford etc dont have to compete with that bcoz no one is importing them cheaper from overseas are they.
We also have to lie some of the blame on nissan themselves, from way back in the day when they decided to bring there cult car out here and show up the "V8 BOYS" now those so called V8 boys are driving round in skylines. it was a nutural progression for them to buy a skyline after the stepped out of there commodores & falcons.
Edited by 85URK
nice rx7 will be a real collectors car :(
ahh thats why we still pay so much in tax for importing cars (well that is the theory) I say stop protecting two companies who are suppose to be australian (both owned overseas) and make it a real competition. Because at the moment we are awarding two companies who really are making lesser qualitiy cars and are even themselves taking overseas cars and rebadging them to try and make up their sales (cough opel vectas). NZ did this and yes they did kill their local companies off, but there are less bombs on the road there as cars are a lot more affordable and come with more safety features then what the old bombs did.
    • Hello, sorry for being late to join the discussion, but my clock just died on me.   Ive tried to look at Michaels digital clock repair.docx and it doesnt work maybe the file has expired.   Please let me know if you can re upload it or take some youtube videos to show us how to get the clock installed? thanks
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
