agreed, I like them...I also like the new lenso widetrack, they're heaps different to the koya's though.
I basically want something chrome, five spoke with plenty of dish... sounds easy enough but alot wheels just don't look right...
p.s. i'm insanely picky :P
anyone who's passionate about cars is insanely picky....chrome is personal preferance, I personally don't like it beacause it's heavy and I like the lightweight race style rims....but thats me.
sooooo true....
yeah i'm a chick and i like bling LOL
but not like crazy wog bling... something that'll suit the car...
I got my stereo installed todays :P:D:D
josh: check out what i found on cardomain lol...I was trolling it for random rx7 pics and saw this....it's the white one in the fs link i gave you earlier..http://www.cardomain.com/ride/358632/7
I had JB do some of my stuff cause i wanted to get it in....and yeah its kinda all screwed up now, and i am going to have to have it done properly. :P not saying you'll have the prob, i hope you wont.
and oh go KOYOS they are made shit....umm try talking ADD racing about a set of those chrome ones i think he may have a set.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
