nope ;)
:pirate:
rofl just had the worst ride home from the airport.. toyota avalon, every couple of mins the car would shake like we're going over a cattle grid.. I asked the driver what the problem was he just shrugs his shoulders "been like that for a while"
oh and morning (sorta) whores... i just got back from gladstone.
lol that woulda been a nice and comforting ride >_<
dunno...new stuff i guess >_<
the room has suddently gotten 'phatter' hi lee! how'd that head unit go?
Hey Isaac, I Dont need it anymore, long story, but i will still be keeping the blue beast and i'll just chuck it into a random persons car later down the track lol
Hoe was Gladstone? Whens the big move?
ahh *i smell a piker* bad luck :happy: why get a shitty gtr anyway, they always break lol.
gladstone was ok, cept dinner last saturday was at this shithouse restuarant - $34 for a steak, i asked well done they bring it out rare, i send it back its burnt charcoal on the outside and STILL rare in the middle.. total rip, i'll never go back!
big move is weekend after this, i start work up there on the 2nd april, so guess i move up on april fools day (appropriate >_<)
Sif order well done for any steak!!!!! May as well eat charcol! ....Medium rare FTW...
various parasites such as hookworms etc.. that live in the muscle of cattle, trust me im a scientist, i like my worms cremated before i eat them >_<
Most decent restraunts will refuse to cook a steak medium-well or well done....just kills the flavour and ruins the steak.
well if they accept my order as 'well done' i expect to see only a hint of pink at best, not blood running out of the middle and a cooked area 2mm thick.
If I pay $30 for steak, I like it to taste good...and like I said, theres a reason all the best restraunts in the world cook steaks only rare or medium-rare...or as the Chef likes (which is rare or medium-rare) and you don't get a choice lol.
    • Manual boost controllers (where a little of the boost was bled off) were quite common back in the day, because they were cheap and easy. Generally they had a manual adjustment screw rather than being fixed like yours. Down side is they always bleed boost, not just when you want them to so an electronic boost controller that uses a solenoid will have less lag.
    • Hello , im new here and i have A31 home build  RB25det neo stock eng / turbo  aem ems 2 blue connector  aem 3.5 map aem cas disk aem wideband connected to ecu  355 lph pump 550 nismo yellow injectors side feed aftermarket regulator  and won’t start with base aem tuner basic tune eventually flipped cas 180 degree so it triggers on correct stroke not in exhaust cycle  Now it won’t start Wideband reads 10 and 11 at lowest fuel setting  and will share calibrations soon for aem tuner i think something is wrong in aem tuner    please if you have any information, am very grateful
