You really are a sex starved little asian arent you?
:yes: guilty as charged... but not really that little :ninja: quite fat actually :huh:
yo smoothy. Pearl for the day....Midget who walk under girl in mini skirt get box in ear.
lol... i like the way this old man thinks :pirate:
me= back from welcome home drive of teh line, after driving shitteh qml rollaz, echo and *gulp* lancer :pirate:
so lee what happened with the swap? no gtr? i can see from your sig the sale went sour?
