You're in the wrong thread for grown up business. This is a shit-pokers thread. Y'know... designed for shoving large shit smeared sticks in each others faces? Yeh that kinda dealie...
Your behaviour is just so wrong.
Hopefully the other member aren’t like this
Look mate. There are thousands of pages of serious discussion on skylines on these boards. The title of this thread should say it all. If this area is not to your taste then just dont come in here. Noone dragged you in and noone is making you stay. Search the forum and you will find all the serious discussion you want.
Ahh he did mention it a while back...but forgot about it. Get him to send a PM then I won't lose track.
sik - thanks :D
My wife is happy enough, we don't need that dirty stuff.
ooooooooooh no toys, eh? Don't people do it like that in dubai?
:ninja: :ninja: :(
I'm in love :D
*whispers* Mrs Palmer must be a damn good wifey!!!
Mate? A mate is a partner. You mean friend?
My mobile plan runs out next month... and I need a new phone. I really want the SE W880i but it doesn't have a light for the camera. Now I don't know what I want. I'm so confused *cries*
Confused aye... Lets explore these confused feelings with the other Anna?
