makes the power and runs the times, but f**k man a stock barina would beat me on the highway
i'd have a guess and say it wouldnt make boost in 1st...:D
and id have another guess and say it'd come on like a farking light switch :)
Yeah you’d guess right, a ca18/20 that’s built as a drag motor, with a t51r should see boost at 5500rpm, and be good for 9000rpm, nothing really streetable about it. Plus it’s always just off its tits I can see it not being a hugely reliable and lasting package.
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
    • Yes that’s another issue, I always have a front mount, plus will be turbo plus intake will big hasstle. I’ve been told if it looks stock they’re fine with it by a couple others who have done it ahahaha.    I know @Kinkstaah said the stock gtt airbox is limiting but I might just have to do that to avoid a defect so it atleast looks legit. Or an enclosed pod so it’s hidden away and feed air from the snorkel and below Intercooler holes like kinstaah mentioned. Hmm what to do
