Do you do trix on him :kiss:
Yeah I bet, I havent seen those fights in person, but pics and movies say nothing but ouch. I have no effort nor the persistence to learn anything remotely close.
Good so from now on dont give me any lip.... :glare:
We can do all sorts of tricks...jump jumps turn in cirlces kick balls...yay fun timmeesss!!
Long story short, I bought one last year, but gave it to dad to cover personal debt and then gave/sold him the Lexus this week to cover my credit card debt, which I bought the BMW on, god I suck at money management.
And keeping your username lol Kofi Ahmed gooood choice NOT
Nah I still give you shit.
I have a bat c**t :kiss:
By trix i mean compete, but i guess not
I used to be dual state champion in a few disciplines aus champ for a while and yeah i was kinda good...but stopped during yr12 due to my horse having an injury of sorts and school load...could never get back into it...its takes a lot of your time up! :glare:
f**k oath it does, some friends where into hard core. I never saw the point, but each to their own - what ever is fun I guess. I went and watched a few, people take it serious eh.
Yeah it is expensive too especially considering you rarely get any moneytary return even if you are good and win! Now i just ride for fun when I i do what i want. I live in hinterland so there hours of trails around and suprisingly it keeps you relatively fit!!
I could never get back into competing again...too much of a piss head..lol
SHOWER TIME>>>you know my address josh..
dont say anything about me while i'm going :glare:
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
