i wouldd but i'm not sure myself.
From what i believe a couple of sau whores went over to bc and started spamming their whore thread, a few insults were passed and a mod from there 'warned' these memebers via sau instead of bc (due to being a mod on both sites).
Since then whoretown disappeared under mod review, then has reappeared but i guess the mods are being 'strict' (to put it diplomatically) to posts.
Yea i heard bout most the boostlosing stuff from josh..don't see why that means whoretown is now being strictly watched/moderated?? Way I heared it, josh, lee and shane etc went over to bc and paid out some ppl, a mod (who, from what I hear, is a friend of the person insulted) chucked a spaz, threw out some ban's on bc and warning points on sau. Sh*t hit the fan...but I mean honestly...meh!! This has nothing much to do with SAU nor whoretown....
yeah no big deal but then Bryn got warning for posting 7 times in a row and then saying he needs to catch up with post counts....
bit on the fascist(sp) side if you ask me :P
lol we should head off to Johns new forum www.offtopic.net.au ;)
they have like 20 members of something..... but everything is a goer there ;):unsure:
bit on the fascist(sp) side if you ask me ;)
agreed, maybe then we can have freedom of speech?
yes that'd be nice now wouldnt it :P
guess what guys...
i wired in my stereo on sat, all nicely soldered so no crappy connections there! ;)
and i also put my interior back together, so it kinda resembles a car now :unsure:
now for that turbo to come so i can send z engine off again :P
i like that you still have your sig shane....people on bc need to htfu!!!
haha yeah, it's a quote from that dude last year, so i dont see why it should leave, plus i agree with you :unsure:
fulleh sik shane.
kektic even :P
watcha get upto on the weekend mate?
Nothing much, i tore a ligament playing basketball on thursday.....so I spent most of the weekend with my feet up watching tv/dvd's and playing xbox lol.
How bout you?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
    • Thanks for the replies everyone. Definitely a coolant push. Oil catch can is empty and always has been. As the engine is out now I'll be having a good look over things. I do have some detonation on the piston tops from a trigger issue back about 5 years ago. I felt it and shut off then bought a new ecu and changed the trigger. Never been an issue since. It never hurt the power, its made almost 80hp more since that incident but I will pull the bearing caps to take a look. If the bearings are damaged I will do a bottom end refresh. Head is being re conditioned at the moment and the block will be cleaned and checked to ensure it's flat. I'll go with a kameari gasket and see how it ends up. The other thing I'm not super keen on is the cylinder colours. I suspect this is from the inlet manifold. The plan will be to put it back together, retune and then stick a plazmaman billet inlet on it and retune. I'm happy with the power, if it makes a little more, then great, but I would rather just make everything more efficient at this stage.
    • Maybe they'll look to do a bunch of presales to help inject some cash fast for their financial issues...
    • Does it also misfire equally when revving?   Josh is very correct in what you should do. The coilpack harness wiring loom itself is a known problem due to its age and the number of heat cycles it has gone through. Throwing parts at a vehicle to diagnose the issue isn't a smart or good way to do it. Secondly, you may have a bad coil pack, you pop replacements in, they fix that issue, but messing with the harness breaks it, so the issue persists. So now you think "well it wasn't the coil packs" and have to continue chasing your tail, potentially swapping back in your shit coil packs and returning the good ones (yes, I've seen people do this because 'it wasn't the problem' and they want to save money). And suddenly, you've got two issues with the same symptoms...   Diagnose, don't use the spare parts shotgun.
