Well, interesting info after talking to transport. As it's me, some downer at court processed the paper work even though no one actually went.. Anyone else I'd say it would have slipped.
Ended up with a 6 month suspension, which is awesome as if I didn't do what I did I would have got 12 months. Love hate situation, I would have liked it to be ignored, but knew it wouldn't have, and only ended up wit half what I should have.
Plus, I've already been self serving it, and will continue to self serve while I don't have a license (thought they might have started it from when i reapplied).
And when I re apply I go back onto my opens. The system works to some degree, yet fails and I only end up with half teh time *giggles*
Edited by Mr Kofi Ahmed
stop Lauging and come join me.... lol see how long before he bans you....
errrmmm ok. It's not his site though, hes not a mod, global mod or admin...hes not anything...how will he ban us. As far as I can see, he's just a member.
re: my request earlier, who here has an R33 and a mulitmeter on them? A free set of dash LEDs for an answer!!!!!
I get positive on the point of the bulb, to be sure I reversed the probes and got a negative.
Congrats Joshwa...only a short while to wait :D
Yeap, not too long at all. Unfortunately the job interview(s) I had lined up will have to be binned, as no license no job, and it's no good going back to the real estate office I was at, as I just cant get there, so it'll be annoying, but I'm not risking driving for such a sort suspension time, last I heard it was upto $3000 and 12 months in jail.. So... Flag that.
It'll give me time to work any hour part time jobs around town and give me the opportunity to have another performance car come re applying time.
yeh bow to my POWAH :D
Probably out of interest and to talk about things other than cars.
yeah, but it costs monehh..and there is no gain....rofl, how are you a global mod :D Use your powah to fix my email!!!
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
