werd....knock on wheels FTW!!!
That reminds me, he found his old Lotus 7 on the Lotus register the other week, still racing hahaha with a billion CAMS log's And his old mustang was in Unique cars not too long ago, It's pretty weird seeing cars pop back up again and seeing how big the race history has gotten.
    • https://www.facebook.com/share/19kSVAc4tc/?mibextid=wwXIfr
    • There is a guy who said he can weld me piping without having to cut chassis, maybe I do that ? Or do I just go reverse flow but isn’t reverse flow very limited once again?
    • I haven’t yet cut the chassis, maybe I switch to a reverse flow. I’ve got the Intercooler mounted as I already had it but not cut yet. Might have to speak to an engineer
