shane i see you there..
i got my tyres today - decided not to use your guy as he was only $15 cheaper ea then i could get locally, fitted :)
ohwell, least he was cheap as i said!
P.S what price and for what did he say?
well i swear he said $115ea over the phone yesterday, i rang him this morning he said $215ea for K104's in 235/45/18.
Tyrepower at slacks creek did them for $230ea fitted, so yeah while chris was cheaper (seemed like a nice bloke too) by the time i drove out there, then found someone to fit them up they would have cost more.
Although he did put me onto a guy in rocky that he knows that will do a good deal on tyres when i get up there.
VERY happy with the car now- with the super streets, offset caster bushes, and good tyres it drives like a new one :)
where r u going? (no, im not even gonna guess ur name cuz i have no idea if it's not your display name)
rockhampton..i WAS going to buderim but got offered more incentive for rocky as noone else was stupid enough to want to work there hehe :) At least it puts me closer to my g/f - she lives in bundaberg.
anyways i'm on a 12 month contract up there so i can handle it.
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
