Why is it that you and I are in all the photos of molesting inanimate objects???
Post the pic of the merkin
i think we just couldnt wait to get to the strip club
wait i like molesting things that cant fight back
I'm sick of getting taxi/bus to work (I got me a job gf-woop.gif) so I'm thinking of getting a loan for a car. I've got $5000 at the moment, probably look for another $15000 on loan, maybe a bit more if the car I decide on needs a bit of work.
I hate the idea of a loan, but I hate public transport worse (takes me 2-3 hours by bus what takes 10-15 minutes to drive, it's insane).
Edit: gf-snypa.gif
Edited by Hell Fire
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
