Before i came to the world of Skylines, this was my first car which i owned for 13 years.
Built it from ground up its no A9X or SS but it would still fair a good price now as they are so rare and with the death of Brocky they have gone up again in price.
It was a beast in its day running a 11.7 at willowbank in 1997 -- until that motor blew it now runs a mild 308.
It still is in the family i was lucky enough to sell it to my old man.
I was lucky enough to go in a genuine bathurst model a few weeks ago, OMG - I changed my veiw on torries very suprised to say the least
Yeah mate there not to bad love the sound of an old V8, but you cant beat the skyline for comfort, cornering and air cond :) .
GO TO BED!!!!! You have all got to go to work tomorrow!!!!
SUCKERS!!!!!!
I am going to TRY and sleep in a bit after a very hectic weekend!!
But I just know some dweeb will ring me too bloody early anyway..........
    • OK, so a bunch of trim needs to come off to get to the rear shock top mounts. Once the seat is out of the way, the plastic trim needs to come off. Remove 2 clips at the top then slide the trim towards the centre of the car to clear the lower clip Next you need to be able to lift the parcel shelf, which means you need to remove the mid dark trim around the door, and then the upper light trim above the parcel shelf. The mid trim has a clip in the middle to remove first, then lift the lowest trim off the top of the mid trim (unclips). At the top there is a hidden clip on the inner side to release first by pulling inwards, then the main clip releases by pulling the top towards the front of the car. The door seal comes off with the trim, just put them aside. The the lighter upper trim, this is easy to break to top clips so take it carefully. There is a hidden clip towards the bottom and another in the middle to release first by pulling inwards. Once they are out, there are 3 clips along the rear windscreen side of the panel that are hard to get under. This is what the rear of the panel looks like to assist:
