f**ken hot sauce. What muffler? I hope that puppy is on a flange for those times you jyst feel like pulling it off :O
So close... So moist
not sure what muffler, but i told him i want it as less restrictive as possible hehe
Who's doin ya tubes and how much shane?
mick from signature (lobb st near us), 2.7k full custom exhaust :D (put it in comparison, CES wanted 2k for dumps and front pipes, and only the rear dump was custom!!!)
Wont you need the engine in the car with turbs for him to custom?
Hopefully forever...7 of the longest months of my life!!
Gay thing is i am meant to be on my opens now but because the suspension i received was backdated to when I was on my p's I have to remain on my p's for an extra...pretty gay...I thought holding a license was hard in a pulsar...gonna be even more fun in a skyline!
