well go with a minor f*&k up on the part of an outside party, and cost isnt the issue
by cost i was referring to the gearbox...
depends how much it is, i wouldnt mind doing a quick rebuild of my box, jsut to keep it live a bit longer
:) lol :(
your box is a bit loose Shane??
nope, i just like to smash it when it gets used, surely you know how it is with these things lee :)
so a bit of preventative measures wont go a stray
whend u say ur missus was going in for 'repairs'? :blush:
dont know yet, but i think the quote for the cryo was under $100
nope, i just like to smash it when it gets used, surely you know how it is with these things lee :ermm:
whend u say ur missus was going in for 'repairs'? :(
lol... home job buddy :blush: just clench and release... :)
Otay no more jokes about about my Missus or i'm gonna go cry in a corner :)
let me know what it is when u pick it up yeah?
also who rebuilt ur box
that's just rude :blush:
hmm spose it was, im sorry....
lol... home job buddy :blush: just clench and release... :(
rofls, yeah i edited that bit about ur missus in, thought bugger it u wont mind 1 attack :)
oh son of rajab what have I done now? ha ha ha
:blush:
lol nothing, just seeing if u'd bite :)
in other news the denver nuggets are leading the la lakers by 10 in their search for 6 straight wins
that's nice, too bad no1 gives a sh!t :(
    • Have you done the Ignition Sync Wizard in the AEM software?
    • Find out what RPM it was idling at with the IACV unplugged. It's very weird that the rpm didn't change at all, and then it stalled. When it stalls is it nearly like a switch off, like you've turned the engine off? Or is it more stutters and sputters and coughs to death over a few seconds? Or does the RPM just slowly keep going down and down? Have you done a test of trying to start it with the AFM unplugged? Does it still die?     If you Follow Josh's advice on using Nistune to check the voltages (which is a perfect method!) if you see anything out of wack voltage wise, THEN get the multimeter out and read the voltage directly at the sensor. If the two vary, then you're now looking for a wiring issue vs a sensor issue. So be aware, what the ECU sees, may not be what the sensor is actually saying too...
    • You very likely need to get it on a dyno and tune it. My assumption is, you've got an RB25DET tune in it, which has a different manifold, different injectors, and different cams as a minimum. What O2 sensor are you running?   When you say it runs extremely rich from idle all the way to redline, is this just free revving it you see that?
    • I seem to the be only person that is using a Haltech 2500 on an NA motor, I've installed a Bosch DBW throttle body to the OEM intake manifold and am having problems maintaining AFR even with the wideband o2.  It will run extremely rich at idle and up to redline, but under load it will go extremely lean in the 20s and i'm essentially having to rev it over 4k and feather the clutch to get it up to speed.  I've read a few other threads of about the butterfly, it seems removing the vacuum to it is supposed to have it remain open, i've noticed no difference under 4k with the vacuum line to it plugged.  I'm hoping someone here has had luck using the NA manifold with Haltech, and if they happen to have a tune for it.
    • I don't know any details, but I really wouldn't be surprised if they do it as a LHD only version, at least initially.
